fully built 85 gmc 3/4 4x4
Discussion in 'Complete Vehicles' started by gn4u2c, Jul 19, 2006.
  1. gn4u2c
    gn4u2c 1/2 ton status
    Oct 29, 2003
    287
    Pa 17329 zip
    85 GMC high sierra origianl 1500 4x4
    Basicly this is 3 trucks in 1 with lots of new extras.
    Now 2500 with fully rebuilt with new gears detriot locker 14ff 4.56 rear disc brake setup
    dana hd 44 up front fully rebuilt with new 4.56 gears also.
    208 t-case rubuilt with new seals, chain pump exc.
    700 r trans with 5 gear sunshells upgraded sprags new clutches band, seals, convertor Bla blah blah
    400 SBC (standard bore) 509 high nickel block from a 29k impala
    all arp hardware,eagle rods,forged pistons, Alloy GM performance parts fast burn (angel port) heads, harland sharp RR screw in 7/16 studs , guide plates, edelbrock performer rpm(vortec style) 77 holly truck avenger carb. custom made wires, mallory disssy, headman ceramic coated d-port long tube headers into true dual with flowmasters.
    35x12.5x16.5 bfg all terrains on Micky thompson classic II wheels.4 wheel dual shock comversion dual steerig stabilizer setup. body off complete frame sanded painted with easwood coral then black rustoleum pain. Ztons of new parts has pl, tilt,cruise,ac(cold) rear slider. warn winch with bumper optima battery balck/silver with charcole int. very nice truck thaqt would be excellent with a paint job. use body from a 2 wd 4x4 shift plate all welded in tight and nice. only had a rust hole smaller than a penny in both cab corner outers only (welded up) the rest of the cab under bed exc is beautiful. small spots on front fender. nothing to worry about unless you paint it put new ones on for a toal show truck.
    has dual 20 gal poly tanks .. Man I could go on all day just come look it over.;)
    I need to lighten the load around here and get some fixer up things done to the house. If you can do pavement we can work out a discount as i need my driveway done.
    Located in pa 17329 zip
    $9,000 is a steal I just spent 6,500 + on the engine less than 500 miles ago. its real strong :bow: not to mention the rest of the driveline. :doah:
    Ask questions have new oem bumer in box if you dont want the winch setup
    will post up pics if you need them but as always I suggest you see it in person.
  2. gn4u2c
    Oct 29, 2003
    287
    Pa 17329 zip
  3. gn4u2c
    Oct 29, 2003
    287
    Pa 17329 zip
  4. gn4u2c
    Oct 29, 2003
    287
    Pa 17329 zip
  5. gn4u2c
    Oct 29, 2003
    287
    Pa 17329 zip
