Fumes
Discussion in 'The Garage' started by screamer, Oct 30, 2006.
  1. screamer
    screamer Registered Member
    May 22, 2006
    41
    Walla Walla Washington
    I have a 73 Blazer with a brand new crate 350, and running it with a carb and points. How do I get ride of these fumes? Will HEI help? Fuel injection? A cat? Or do I need a new carb? I want to run a soft top but with these fumes I'm afraid I'll gag my kids. I rerouted my exhaust to the side right behind the rear wheel. It helped some but still gets drawn in through the rear window when it's open.:confused: :mad:
  2. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    i dont know alot about this but i heard if you put a wing on the top it deflects air downward and not into the cab
  3. dremu
    Feb 27, 2000
    15,970
    462
    East of San Francisco
    Changing to HEI will make your life infinitely easier but won't rid you of the smell. You may be running rich or something, but in general, K5's often get exhaust inside with the back window open.
    Soft-top might help, as it'll change windflow. Soft-tops are NOT airtight =))
    The wind deflector on the back might help, push the exhause away from the window.
    Also, running the fan inside creates a positive internal pressure, which should feed (relatively) clean air from outside into the cab.
    Or go topless. You have a full-convertible rig; use it! :D
    -- A
  4. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    491
    New Hampshire
    I am disapointed, I thought this thread was about the "other" Fumes. :rolleyes:
    :haha::haha::haha:
  5. dremu
    Feb 27, 2000
    15,970
    462
    Yeah, I thought, dang, what's the sheep man doing out of The Lounge?
    -- A
