FumeY Exhaust
Discussion in 'The Garage' started by Justin Fleming, Sep 28, 2005.
  1. Justin Fleming
    Justin Fleming 1/2 ton status Premium Member
    Aug 24, 2005
    767
    4
    Oxford MI
    I have noticed that my 305 k5 has very fumeY smelling exhaust at idle. I can let the truck idle for 20 minutes and then check the plugs and they are very clean almost white(but this dam near runs you out of the garage). The truck does not seem to run rich nor is there any driveablity issues either. The pipes are a little sutty.....
    Open to all suggestions....
  2. 350k5
    350k5 1/2 ton status
    Feb 15, 2005
    115
    Bloomington, IN
    Well your catalytic converter is what takes away those fumes. My guess is yours is either going bad or you may not even have one. Then again driving down the road with no cat you'd still smell is pretty heavily. You might have a leak in your exhaust before the cat. That's what it sounds like considering you only notice it while sitting still. Check to see if there are any holes and go from there. Good Luck.
