Fun day in the world of K5 repair
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Pugsley, Jul 3, 2001.
  1. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I finally got around to going through my steering column today - Got pics to post for steering column virgins atleast. All went well taking it apart - except for finding that the dimmer switch rod was existing as two seperate pieces. How that worked was beyond me. I also managed to break my E-8 external torx socket on the first bolt. Took a nice 2 mile walk to Napa in 114 degree weather, and picked up a new one. Got the column all tightened up and started putting everything back together, when lo and behold, I realize that I neglected to deal with the broken dimmer switch actuator. Took everything apart and fabbed up a new one, started putting it back together again, and here comes the @#$%^&* monsoon with rain drops the size of softballs. Threw everything in the cab and started working from inside - atleast until it got too hot to breathe in the cab. At this point I found it necessary to go drink beer in the backyard until the rain blew over, finally finishing the thing up about an hour ago. The moral of this story? Never believe that just because you've done a job a dozen times with no problems that it will work this time. Sorry - just had to vent[​IMG]
    If it weren't for bad luck, I'd have no luck at all[​IMG]
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A>
  2. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    I hear you. I ripped my dash apart to cure some raunchy rattles from it's nether regions only to discover I forgot to r+r the burnt out bulb behind the speedo. After I put it all back together, of course.
    Shawnboy.
  3. 80blazer
    80blazer Registered Member
    Mar 4, 2001
    41
    glendale arizona
    A fellow Arizonan I thought the monsoon thing sounded familure I feel your pain man had to deal with two electrical fires yesterday and it was hot! Hey Pugsley I see your a fellow Firefighter who do you work for. Talk to you later. Jeff
    Its time to lock them in!
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I ripped my dash apart once cause all my dash lights had burned out...I meant to check the fuses but forgot, then remembered as I was finishing taking the thing apart.
    90K5
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Ya, I never figure i can do the same job more than once is the same alotted time period. Somethign always goes wrong and ends up adding time!!!!
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://www.geocities.com/emmettology101>http://www.geocities.com/emmettology101</A>
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Whats so 'nice' about the 'nice two mile walk' in Arizona?!?! [​IMG][​IMG] Especially when its 114 degrees out!!! [​IMG][​IMG]
    <font color=red>I m so we Todd did.
    I m sofa king we Todd did.</font color=red>
  7. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Yep...no job is ever easy!
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  8. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    that sounds like the day I repacked the hubs on my new axle... [​IMG]
    [​IMG] <font color=blue> Jeff </font color=blue> [​IMG]
  9. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I'm unemployed at the moment - I got injured, and my "temp" moved right in to my job. Soon to be headed for either Tucson or the Valley.
  10. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    It was really nice - I probably managed to lose 15 pounds between the heat, the humidity, and the fact that it's mostly uphill[​IMG]
