Fun tring to find problem!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cmoe, Mar 10, 2001.
  1. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Well wnet out to the k-5 this morning and started it. ran for about 2 min. then died. And I couldn't restart it even with "Starter fluid". She would crank but no firer.... So went to the part store and picked up a new cap, rotor, HEI coil, wires and plugs. Installed them all and still no fire... Barrowed a friends timing light to see if there was a spark....no spark..... Tomarrow I need to see if I can find the short..... Wish me luck......
    C'moe
    <font color=black>the blazer is "Back in Black"
  2. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    Check to see that the coil has power. If it does then your HEI ignition module is probably toast. These things are about $20 depending on the year.
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    It sounds like your module is toast. You can remove it and have it tested.
    creepin' and crawlin'
    Jim
  4. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Thanks guys I'll get a module and see if thaat fixes the problem. Didn't think of that one yet...
    that was it!!!! it works again....
    C'moe
    <font color=black>the blazer is "Back in Black"<P ID="edit"><FONT SIZE=-1>Edited by C'moe on 03/11/01 04:32 PM (server time).</FONT></P>
