Funky Factory Tint
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cavalry, Feb 25, 2001.
  1. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    I just got a tailgate out of a 91 jimmy. The glass has this funky tint (looks like a million dots) Whats the deal with it (why not just regulat tint) I'm guessing better visibility? Were the side windows tinted with the same crap? Does it actually look ok installed in the truck? Right now its on my shop floor, and I'm really not liking the look of it.
    Luke
    84 K5
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    My '90 has it. If you are over a ft away you can't tell what it is. I suspect this type of tint was used due to the abuse the rear window takes from the being run up and down. I don't think an aftermarket tinting film would last very long. The side windows are not tinted the same way.
  3. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    If they are really small black dots then it's supposed to keep the sun from beating in on ya. They use that tint on a lot of sunroofs to spare the driver/passenger from the sun.
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
  4. pr1aw
    pr1aw 1/2 ton status
    Sep 17, 2000
    144
    San Diego CA
    My 91 has a solid factory tint on the rear window along with the sides.
  5. kenbrown
    kenbrown Registered Member
    Feb 9, 2001
    20
    Utah USA
    that is an expensive window! mine broke so i called the dealer to get one. the tinted one was almost 500 bucks!!! and the regular just over a hundred. personaly i like the tint. from inside it is easier to see out than the regular.
  6. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Does your rear window have laminated glass like regular factory tinted windows (tint sandwiched in the middle of two pieces of glass)? Mine's got that stupid dot tint, except mine is thousands of little holes, not dots.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  7. Cavalry
    Oct 1, 2000
    978
    Its thousands of clear dots. The tint is on the inside of the window (I can feel the texture with a fingernail) I cant roll the window up yet to look at the stamp to see what it is. Hopefully between my trashed out tailgate and this one I'll have everything I need.
    Luke
    84 K5
