Funky Names
Discussion in 'The Garage' started by Confedneck, Aug 4, 2003.
  1. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    For tools...heard a socket called a bolt fugger today...wtf? anyone else got any cool names for tools?
  2. TK5
    TK5 1/2 ton status
    May 29, 2002
    319
    Fairview , Tennessee
    Big Hucking Fammer!!!!! or BFH!!!!!!!!
  3. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i just heard of a pickle fork the other day, that's a pretty wierd name
  4. Confedneck
    Nov 1, 2002
    5,236
    blue tipped touch wrench?
  5. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I don't even know the real name, to me it has always been Pickle Fork....
  6. Confedneck
    Nov 1, 2002
    5,236
    it is technically called a pickle fork...
  7. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Ethiopean jug ##cker
  8. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Liquid wrench. Referring to that case of Budweiser.
    Drank after the engine was out, in the "take apart" mode. /forums/images/graemlins/rotfl.gif
  9. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    Hot wrench
    Blue wrench
    Boobie fixer (nail puller)
    Bubble stick (level)
    pursuader (BFH)
    Metric wrench (Crescent wrench)
    Kill saw (Skil Saw)
    Rene
  10. Confedneck
    Nov 1, 2002
    5,236
    wtf is that?
  11. Greg72
    Mar 5, 2001
    15,682
    1,392
    642 Days to BB2018
    This was obviously taken from some sort of motorcycle context, and isn't really about funny names.....but it certainly has funny explanations for what tools REAL purposes are!!! /forums/images/graemlins/thumb.gif
    HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive parts not far from the object we are trying to hit.
    MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing seats and motorcycle jackets.
    ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets in their holes until you die of old age, but it also works great for drilling mounting holes in fenders just above the brake line that goes to the rear wheel.
    PLIERS: Used to round off bolt heads.
    HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
    VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
    OXYACETELENE TORCH: Used almost entirely for lighting various flammable objects in your garage on fire. Also handy for igniting the grease inside a brake drum you're trying to get the bearing race out of.
    WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for the last 15 minutes.
    DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted part you were drying.
    WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar callouses in about the time it takes you to say, "Ouc...."
    HYDRAULIC FLOOR JACK: Used for lowering a motorcycle to the ground after you have installed your new front disk brake setup, trapping the jack handle firmly under the front fender.
    EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a motorcycle upward off a hydraulic jack.
    TWEEZERS: A tool for removing wood splinters.
    PHONE: Tool for calling your neighbor to see if he has another hydraulic floor jack.
    SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog-doo off your boot.
    E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit.
    TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup.
    TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile strength of ground straps and brake lines you may have forgotten to disconnect.
    CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle.
    BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid from a car battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought.
    AVIATION METAL SNIPS: See hacksaw.
    TROUBLE LIGHT: The mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under motorcycles at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
    PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; can also be used, as the name implies, to round off Phillips screw heads.
    AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts last tightened 60 years ago by someone in Springfield, and rounds them off.
    PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
    HOSE CUTTER: A tool used to cut hoses 1/2 inch too short.
  12. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    wtf is that?
    Any tool that fall's, and roll's to the center of the vehicle, when you are working under the hood. Another form of Murphy's Law.
  13. Confedneck
    Nov 1, 2002
    5,236
  14. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    "Gas Ax" aka Oxy-Acetylene torch /forums/images/graemlins/thumb.gif
  15. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Smoke Hatchet. [acetylene torch] /forums/images/graemlins/eek.gif
  16. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Portable Press: [hammer] /forums/images/graemlins/eek.gif
  17. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Alway's use the correct tool for the job.
    Never use a Big Crescent Wrench to hammer with, Use a small one. /forums/images/graemlins/eek.gif
  18. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Chicken Stix
    a combination of a Screwdriver, Punch, or Chisel
    clamped with vise grips. cant really remember how to use it, but thats what my buddy called it
  19. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    i didnt know what i was supposed to bring someone when i heard:"get me a pair of dikes" for the first time. /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
  20. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    [/ QUOTE ] /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
