Funky steering question on '89 Blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by etr, Oct 20, 2002.
  1. etr
    etr Registered Member
    Oct 20, 2002
    5
    San Mateo, CA
    Funky steering question on \'89 Blazer
    Hi y'all,
    I'm new here, but will probably be back, since I bought a really, really nice '89 Blazer. It has a steering problem though, that I could use some advice on...driving on city streets and on the freeway, the steering does small random jerks from side to side. Not enough to really cause trouble, but they're annoying. The truck has a rebuilt steering box. So, I'm thinking rod ends, wheel bearings or ball joints. I could use help in how to trouble-shoot. What're the least expensive parts to replace first? What special K5 tools do I need to R&R myself? How much for a shop manual?
    Thanks in advance!
    Eric
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Re: Funky steering question on \'89 Blazer
    Does it have the auto-locking front hubs? Mine will do the same thing if I dont unlock them bu backing up 20 or so feet.
  3. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    Is it lifted at all? Could just be a slight case of bump steer. Fill out your profile, that way it easier to see what you have and give suggestions. Oh yea welcome /forums/images/graemlins/grin.gif
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Check your tie-rod ends. That would be my first guess. Next guess would be rusty/stiff front axle u-joints.
    Haynes manual for your truck (73-87 pickup) about 15-20 bucks.
  5. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Same thing here, front auto hubs where trying to ingauge. Pulled hubs everything looked ok so I regreased them and reinstalled. Started driving and it done it again. So I kicked the 4wheel shifter a couple times it went away. Get someone to help and readjust the 4wheel shifter on the floor. Mine happened after dropping the body back on the frame with 1" blocks and new body bushings (about 2-2.5" of lift). Good luck. /forums/images/graemlins/thumb.gif Jeremiah
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Hey everyone seems to overlook the tires.
    I had a similar problem and after changing everything, I found that the tires had worn spots.
    Replaced them with new and no more problems.
    So check those too.
  7. etr
    Oct 20, 2002
    5
    San Mateo, CA
    Thanks all, for your suggestions. So, I took delivery of the truck and while tanking up I checked the tire pressure. Doh! 45 psi in the fronts! What was the DPO thinking? Took it down to 30 psi and the problem has disappeared.
  8. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    So check those too.
    Yes, older tires tend to follow the grooves on the freeways. My motorcycle had a front tire getting worn, and everytime I rode on the freeway, the front tire would want to follow the grooves /forums/images/graemlins/shocked.gif
  9. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Never fails, tires are always overlooked.
    Glad you found the problem.
