Funky Turn Signals
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nate87k5, May 1, 2000.
  1. Nate87k5
    Nate87k5 Registered Member
    77
    Phoenix, AZ
    My, turn signals are acting up. Need some help. When I turn them on(right or left) They do not blink at first. Then when they do...they blink spuraticly(sp). Dont know much about the electical system so any help would be appreciated. 87k5
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Could be a bad ground wire or the flasher that plugs into your fuse pannel. first place to check anyway.For the grounds, locate them and if they are still hooked up remove and sand down to make a fresh contact.If not then replace the flasher!
    Good luck
    Rock ON![​IMG] 72 K5 [​IMG]
  3. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    Since it is both signals I would say a faulty flasher ??
  4. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Nate,
    Do you have a wiring diagram?? If not I can scan one in for ya....
    <font color=green>[​IMG]Eagle86K5[​IMG]
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    It really does sound like the actual flasher fuse is shot. A couple of years ago, my truck did the exact same thing, but if I fiddled with the turn signal handle enough I could get it to work. It also signalled really wonky at times. I finally replaced the flasher and voila- fixed. Sometimes the easy fix does work!
  6. **b**
    **b** 1/2 ton status
    279
    KIllington, VT.
    off hand i would say there's 2 flashers...
    round things on the fuse pannell...
    swap em' ....
    i may be wrong....
    flasher though is an easy fix about 4 bucks tops...
  7. **b**
    279
    KIllington, VT.
    how about the hazzards????
    they any good ?????
    went this route b4...
  8. MICHIGAN BLAZER
    MICHIGAN BLAZER 1/2 ton status
    296
    Middleville Michigan
    I agree with **b**, swap your hazard relay w/your blinker relay.....that should solve your problem....them go buy the relay you took out...$2-$4.
    <font color=red>MICHIGAN BLAZER
    <font color=green>89 Fullsize Blazer
    87 Cherokee
    65 IH Scout
