funny glow plug controller
Discussion in '1982-Present GM Diesel' started by colbystephens, Jul 31, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    ok, so my controller makes this wierd grinding noise when it's on. it doesn't just click on and click off. today my glow plug controller would only glow for about 4-6 seconds. which was enough, but i'd like to glow closer to 10 seconds, and when i released the button and then pressed it again it wouldn't work. any thoughts?
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    You running some sort of manual glow plug set-up?
    Rene
  3. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
  4. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Sounds like time for a new relay
  5. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    how much do those go for?
  6. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    also, if it goes out on me, is there a way to manually cycle the glow plugs - like touch a certain couple of wires to the battery? seems like i could possibly touch the peg on the controller which points toward the engine to teh positive terminal and that should do the trick.
  7. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Grounding the light blue wire will force the GP's on, bypassing the controller completely. If the relay is done you're SOL though. At least they're pretty cheap, usually under $20.
    Rene
  8. diesel4me
    Jul 24, 2003
    17,577
    943
    Massachussetts
    not really..
    I've jumped glow plug relays with a pair of pliers..just bridge the two big red wires together with them ,or a peice of heavy wire..or jumper cables..ten seconds later,start it up,and remove the jumpers..--who needs a working relay??..:D
    Had to do that to my winch a few times too,when one of the solenoids rusted up ,and refused to engauge..:crazy:
  9. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    good info - thanks!
  10. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    If it's over 80 degrees shouldn't need the GPs at all.
  11. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    that tip will come in useful one day a year...i live in portland oregon. :wink1:
