Funny klunking when I shift gears with my SM465
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 72Blazerod, Mar 16, 2002.
  1. 72Blazerod
    72Blazerod 1/2 ton status
    May 18, 2000
    264
    Vancouver, British Columbia, Canada
    It seems that since I bought my truck about three years ago, if you don't play the clutch just right you get a violent thunk sound and fell from it. I was watching the rear drive shaft while the numb skull at the "AirCare" station shifted gears on the dyno. Holy cow, the rear drive shaft was bouncing up and down pretty bad. I have gotten pretty used to it and can shift it pretty smoothly but if anyone else drives it, it is klunk-city. Has anyone else experienced this? Is there anything I can do to get rid of the klunking?
    Let me know,
    Rod
  2. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    well- just dont' let anyone else drive it, then it wont klunk
    sorry thats about as technical as an answer as I can give you LOL
    Brandy
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    new shaft?
    there will always be some 'clunk' in it
    think about all the gears and couplers that have operating clearance
    it all stacks up
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    check the tranny transfercase mounts
  5. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I second mudhog, check all your mounts for decay or severe wear!
    BTW, if you have a slip yoke, try removing the driveshaft and stuffing some grease into the yoke, then reinstall and see if it's reduced. I have a lot of wear on either my output shaft or slipyoke, so every now and then I pull it, load it up with grease, and it quiets down a lot. Bad mounts will cause the yoke to slide in and out more, causing some more wear, too.
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Check U joints also. Your tranny may just need freshening up. You could also have slop in the rearend. How are your driveshaft angles? Are your ujoints phased properly?
