Funny noise at 50 mph
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JDELBLAZ, May 11, 2000.
  1. JDELBLAZ
    JDELBLAZ 1/2 ton status
    140
    STAMFORD C.T
    well im stumped with this one and need help when im on the highway doin about 50 with the throttle pressed no noise but as soon as i let off the throttle it makes a load growning noise press the throttle again and its gone you get the picture and dont tell me keep it flored or somthin like that lol your help would be great thanx in advance
  2. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    Could it be your rear gears? Check them by jacking the rear and running the truck just like on the road. I had a similar noise but it was constant. It turned out to be the rear pinion bearing. Block the front tires too. Hope it isn't an expensive fix.
  3. JDELBLAZ
    140
    STAMFORD C.T
    sorry i forgot to mention the noise is in the front
  4. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    What year K5?, what engine,tranny,transfer case?
    If NP203(full time) you might check your front spindle bearings. These would be the needle bearings that your stub axles ride on just outside of the steering knuckles. Or your ring and pinion gears.
    Mud is just thick water, or is it that water is just thin mud?
  5. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    i just had the same prob...it was buggin me for about 6 months....it ended up being my drive shaft angle being too much...check your drive shaft first....i ended up havin to put a drive shaft with a cv joint in it....not one noise now =-)
    Chaz
    "whoo my new pic is on the photo page...check it out!!"
