Funny noise
Discussion in 'The Garage' started by dheavychevy38, Aug 17, 2005.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    Ok so my k5 has been makeing some noises lately and they are startin to scare me. When you let off the gas around 65 it would make a ching sound like somethin was just flopin around i have checked everything and it is all in good working order. NOw whne you start the truck you get a knock like something is hitting but everything is aok. Any ideas would be great thanks guys Denny.
  2. BlazerFarm
    BlazerFarm Texagonian Premium Member
    Mar 19, 2003
    1,275
    6
    Gresham, Oregon
    Have you checked your u-joints? They may be worn out.
  3. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    yeah they are all new
  4. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    motor mounts? tranny/t-case mount?
  5. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    The only mounts that are not new are the motor mounts other wise everything under the truck is new or remaned thats what worries me.
    Now when you hit a bump yyou get a ticking noise like two bolts hitting. If you come to a stop it goes away.
  6. resurrected_jimmy
    May 23, 2005
    2,241
    front drive shaft hitting crossmeber? I had something similar with mine and it turned out to be a broken motor mount
  7. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    it is only when you drive onthe street.
  8. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Do you have an automatic trans? Could be the flexplate is cracked.
    Jimbo
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The ching sound is u-joints more than likely . I described that sound to Marv , he said joints , replaced them all since its been a whole wheeling season and then some . And Marv was right .
    The other noise could be a starter loose , or the solenoid is failing if its only when starting .
