funny noise
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gill, Oct 31, 2001.
  1. gill
    gill Registered Member
    Aug 3, 2001
    37
    memphis and murfreesboro, tn
    Hey whats goin on folks? I am having a little problem and any kind of help would be much appreciated. When I drive on the interstate for a while about 2-3 hours, my truck starts to make a loud roaring noise and begins to vibrate my truck really bad, it sounds like when you run over those grooves on the side of the interstate. When I stop and shut the truck off the noise stops but it only happens at about 60 mph or over and gets louder as I increase my speed. Well if anyone has had this problem any kind of help would be great. Thank You
    88 College K5
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Check the fluid in your differential and see if your tranny fluid smells burnt.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  3. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Check all your tires. I had something similar recently, and it turned out to be a big bubble in my right rear tire. A steel belt had snapped, and I guess right after it happened, it was just like you're describing, and eventually became constant no matter what speed or how long I was driving on it...
    This is just theory and may be a little off, but it may take some time because the tire heats up and the air in it expands, which would push out the rubber where the belt had seperated.
    Good luck!!
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    Welcome to America.
  4. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Check also the fan clutch, it may be hanging up at high speed and turning, it'll roar like you're describing.
    Still a very pissed-off
    White Knight
  5. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I would check the rear diff and the u-jt's as well... does it only do it after a long time at freeway speeds?
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
