Funny rear wheel noise? - 88 k5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by drsnazzy, Aug 28, 2006.
  1. drsnazzy
    drsnazzy Registered Member
    Mar 2, 2006
    19
    Phoenix
    Hey everybody,
    I'm hoping for a "collective diagnosis" from you guys.
    After a highway trip the other day, I was taking a slow corner at a stop light and heard a 'tunk' sound coming from the driver's side rear wheel. After investigating a bit, it seems to only happen at slow speeds when I'm turning. When I'm over 10 mph or so and/or going in a straight line, it's not there. It goes 'tunk', 'tunk' at a slow, unpredictable rate, almost like the axle or wheel is getting hung up internally.
    What do you guys think? I'm a shadetree mechanic with my trusty service manuals, so any help saves me from paying to get it looked at. I can usually fix things if I know what the problem is...
    THANKS!
  2. drsnazzy
    Mar 2, 2006
    19
    Phoenix
    Oh yeah - I forgot to add that this is an 88 350, new rebuilt 700r4. The clunk (tunk?) doesn't happen when I put it in gear -- only whn I am crawling and have the wheel turned, generally with my foot lightly on the brake.
  3. nutsthename
    nutsthename 1/2 ton status Premium Member GMOTM Winner
    May 29, 2006
    350
    Pageland, SC
    Mine was doing that and I discovered that it had a limited slip differential. I changed the oil and added a tube of Trans-x limited slip additive and it hasn't done it since.
  4. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I'd say if its sporadic double check the u-joints and rear pinion for play and then you may wanna check your gear oil level in the rear axle and make sure its not the factory gov-lock threatening to go bye bye.....
    you may just be hearing it engage and disengage
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Something similar with my old rear axle. Ended up being that one of the 'pins' that holds the drum brakes in place had broken, and some random parts were bouncing around in the drum. At speed, they apparently found a resting place, but coasting along, thunk, thunk, clank....
