Funny sound from engine???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, May 8, 2001.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I know I've heard this noise somewhere else... When I hard accelerate, not really from a standstill.. I hear a rattle from the motor... I havent heard this noise before.. this is a fairly new GM Crate motor... It doesnt do it all the time... I have to mash it to the floor boards... it's almost sounding like the lifters or something are lifting too far and jumping on the cam... My dad's 4.3 in his 89 s-10 makes this noise once and a while...
    [​IMG]See me at <A target="_blank" HREF=http://www.inhomenetworking.com/78jimmy.htm>http://www.inhomenetworking.com/78jimmy.htm</A>
  2. xtreme_wlr
    xtreme_wlr 1/2 ton status
    Mar 22, 2001
    103
    San Diego, CA
    Uhm, that is commonly know as detonation (or pre-ignition or something of the sort). Try putting a higher octane gas in it and see if it stops. Also try retarding the timing a little to see if that helps cure it. That is what it sounds like you are describing.
    '78 Chevy 1 ton Stepside RockCrawler
    468 BB, SM465, NP205
    D60 front, GM 14Bolt rear w/ Detroit
    <A target="_blank" HREF=http://65.11.18.114>http://65.11.18.114</A>
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    your timing is to advanced try backing it off just a hair and you will be fine
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
