funny sound when i turn left,it sounds like...
Discussion in 'The Garage' started by boggerless, Mar 4, 2006.
  1. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    a tire rubbing almost??i thought it was the u-joint from the front driveshaft rubbing on the t case mount.but there is no visable wear.its worse when i give it gas.my t case mount is pretty crappy,could it make something rub? like i said its only when i turn left. thanks daryl:grin:
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the front driveshaft CV when rubbing on the crossmember sounds like a bunch midgets hitting the frame with a hammer.
    it could be that, when you step on the gas, the motor rotates to the right, and turnig left would make it rotate right. sounds like you may need to replace both the motor mounts and the tranny mounts.
  3. boggerless
    May 26, 2003
    22,728
    96
    :doah: i always forget to give details. its a 79 jimmy,350/350, 203 t-case. six inch lift with 36in tires. with manual hubs.:D
