Furnace Problems
Discussion in 'The Lounge' started by Resurrection_Joe, Dec 7, 2006.
  1. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    It's 55* in the house
    I have fuel oil furnace
    I just had the thermostat replaced
    It cuts out intermittantly and I have to reset it to get it work.
    It usually only woks fo a while and then dies.
    It seems to happen on cold nights....
    Any ideas?
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Move to Arizona.
    Winter heating problem solved. :D
  3. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    Buy a better Chinese cook? :dunno:
    I have nothing useful to contribute.
  4. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    Right now it is 35* outside, I'm sitting here in my drawers sweating, it's 80* in here.
    I have electric heat and my electric bill was $27 last month.
    I live in the basement apt and the two places upstairs have gas heat.
    The furnaces are in the basement.
    Being a metal smith I tapped into the ducts and made up some beer box ducts. I had to rework them so I could shut them off.
    Whew it's toasty in here, think I am gonna open a window.
    :p:
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    These are 2 of the most common reasons for problems with fuel oil heat.
    cloggd filter/water in line.- Instal new filter and clean out filter cup
    dirty orfice- pull buner out, remove fuel nozzle and clean it out.
    If those fixes dont work remove a tire from your car and light it in your living room.
  6. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    I`m willing to bet its the orfice. Mines been doing that for a year now...guess its time to replace the burner (has a 50s or 60s burner now)
  7. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I'd suggest the nozzle. They're recommended to be changed once a year. I guess I'd suggest the filter, too, it's easy enough to change.
    The reset is usually triggered by the burner running without burning any fuel (power is applied, but there's no ignition).
  8. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Mine did a similar stunt recently..............I "bled" it like you do a brake system.
    Narry a problem since...............where's the fingers crossed smiley?
