Fuse block
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by '73 K5, Jul 18, 2001.
  1. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    My fuse block is really loose; I think the wires are the only thing holding it up. I found one screw on the upper right side of the block, but when I tried to tighten it, the dang thing was stripped out.
    I didn't see any other screws OR holes. Any ideas on how to secure it better? TIA
    '73 K5
    Chevy good...Ford bad
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Check to see if you can tell what the screw goes into, you may be able to put a corser threaded screw or a slightly oversized screw into the same hole.
  3. Medman74K5
    Medman74K5 Registered Member
    Jun 7, 2001
    48
    Arizona, Prescott Valley
    Should be two screws 1 on top right, the other bottom left. If a larger screw doesn't work put a nut on the other end.
