fuse block????
Discussion in 'The Garage' started by jacked_86chevyk10, Mar 15, 2004.
  1. jacked_86chevyk10
    jacked_86chevyk10 Registered Member
    Feb 4, 2004
    42
    SNELLVILLE, GA
    does anyone have what each fuse is in the fuse block? i think ive blown a turn signal fuse but im not sure and all my labels have faded off- i have head lights but jus no turn signals- any other suggestions of what it might be would be greatly appreciated!!!! thanks fellas /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  2. jacked_86chevyk10
    Feb 4, 2004
    42
    SNELLVILLE, GA
    i think this might help too- duh- its an 86 chevy k10 scottsdale-thanks
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Look at your other post. If I was at home I would take a pic of mine , its similar. Try pulling all your fuses one at a time and checking them. /forums/images/graemlins/waytogo.gif
  4. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Turn the key and park lights on, use a test light and check both sides of each fuse. Faster than searching for a fuse diagram or pulling each fuse to visually check. Also replace your turn signal flasher, could be worn out. /forums/images/graemlins/thumb.gif
