Fuse box upgrade
Discussion in 'The Garage' started by xblaxermnx, May 8, 2006.
  1. xblaxermnx
    xblaxermnx Registered Member
    May 31, 2004
    62
    In a state of flux
    Ok I know this is an easy upgrade but I found this fuse box in a junkyard. It was in a 1994 Dodge Caravan. Cost me 10 bucks and has room for 7 relays and a 10 position fuse panel. Also the outputs of the relay circuits can be fused with 30-50 amp circuit breakers as well. I modified the wiring of the box for 5 fused constant 12+, and 5 switched 12+. I cleaned the rest of the box and all contacts with contact cleaner, powder coated the mounting bracket and installed on my second battery seperate from the main electrical circuits.
    Now I just need to find some Windstar fans, about eleventy billion lights, several more amps, and and and and
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    nice score.....
    I bought a unit off of a 1989 olds 88
    8 relays.. standard and waterproof
    16 fuses....
    mounts right on the firewall with factory bolts... sits on a angle but hey it bolted right on :haha:
