Fuse Panel Diagram needed - don't have haynes manual:(
Discussion in 'The Garage' started by mickscanoe, Apr 7, 2007.
  1. mickscanoe
    mickscanoe Newbie
    Apr 5, 2005
    Centennial
    i need a fuse panel diagram for my 91 350 K5
    no haynes manual yet, just trying to throw a radio in . . .
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    It should all be labled. That is more than the amount of information you would need to wire a new stereo.
  3. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
  4. 1BadK-30
    1BadK-30 1/2 ton status
    Feb 6, 2005
    817
    Phoenix, Arizona
  5. dyeager535
    26,978
    Unfortunately, '91 is entirely different than the '77.
    It's easy. Use a voltmeter, find the accessory terminals along the top of the fuse panel, use one that is 12V constant for the radio memory wire, and use one that is on in every position but off/start for the main power. You can use a spade connector to fit in the terminals, or you can go to the wrecking yard and get stock connectors to lock in place, which can also allow you to "piggyback" connectors if there are no empty slots.
  6. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    There is a 1980's diagram there also, allthough they could have changed in 91 I'am not aware of.
  7. dyeager535
    26,978
    Changed again in about '84-85...first style blade fuse panels had accessory terminals randomly scattered about, later blade fuse panels had all the accessory terminals along the top edge. :)
    it's not tough, use a voltmeter to see when each one has voltage, and pick the right one for the memory and ignition 12V source.
  8. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    Ahhh I see, thanks for clearing that up for me.
