Fuse question
Discussion in 'The Garage' started by muddybuddy, Aug 27, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    my doorlock 30 fuse was shot so i pulled it out. it was extremely hot. i put in a new fuse and after using the door locks successfully a couple times it died too. i pulled it out and it too was extremely hot. what can i do about this? can i put in like a 40 or something? i think its getting too much juice, but what do i know??
    any help is appreciate. thanks
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    putting a higher amp fuse will not slove the problem you have a problem some where else in your wiring. If you put a larger fuse in there you might start frying your door lock motors insted of the fuse
  3. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    bad idea, find out why its blowing.
  4. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    alright, what should i look for? where is the most common place for this to happen?
  5. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    If you know how to use a multimeter you can use that to find shorts or breaks. Otherwise try unplugging the door lock from one dorr and try it and see if it works then the oterh door and start isolating the problem by trial and error
