FUSE!!!
Discussion in 'The Garage' started by CHEVY 4WD, Mar 24, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Ok all my fuses are good except for the one that is labled HORN it keeps blowing I even tryed a bigger fuse blew it too. Needless to say the horn wont work but also the radio wont turn on the dome light donsent work and the tach dosent move. Any idea's? /forums/images/graemlins/1zhelp.gif
  2. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    sounds to me like you have got a wire touching somewhere. Try tracing your wirng and looking for a bare spot or a place where it has arched to a ground. Most likely you have got a broken or bad wire somewhere in that circuit.
  3. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    heres a tricky way to do it get a piece of wire and use it as a jumper in place of the fuse and look for the smoke of the wire wheres its touching then get the jumper wire off... it works but got you need to be careful /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif www.zombieoffroading.8m.net
  4. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Ill burn somthing up like that
    No one else has EVER had this problem?
  5. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    it pops b4 I can even turn anything on besides the truck(i think) but that might have somthen do with the tach
  6. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    my fuse pops if i use the horn for more than a few seconds, but the horn works fine, and so does the radio
