FUSEABLE LINK
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ZfromNJ, May 30, 2001.
  1. ZfromNJ
    ZfromNJ Registered Member
    Jan 26, 2001
    99
    New Jersey
    I am having a problem with my fusable link. I have a 1974 Blazer and yesterday I went to go start my truck and nothing happened. My horn didnt work or my lights. BUt when I messed with the fuseable link I was getting things back slowely, then it died again on me. ANY SUGGESTIONS?
    {crazy}
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Generally, a fusible link is either good or bad. If you managed to get the 2 ends inside to touch you could get current flow, but it would be very intermittent. You could have a bad connection where the link is bolted on. As always....check for a good ground when looking for electrical gremlins.
    Michael[​IMG]
    <A target="_blank" HREF=http://www.jmartin.net/parker/goose.htm>http://www.jmartin.net/parker/goose.htm</A>
  3. dyeager535
    26,980
    If you have that easy access to the fusible link, check continuity with a multimeter. Easy enough to do, and will tell you immediately if it is the cause or not.
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
