fuses for electric fan install
Discussion in 'The Garage' started by MudFlap, Nov 22, 2003.
  1. MudFlap
    MudFlap 1/2 ton status
    Dec 2, 2002
    250
    Winston-Salem, NC
    From what I've seen, no one runs a fuse anywhere when they wire up their fans. Is this right? Or am I missing something?
    Trey
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I used 20 amp breakers.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You should ALWAYS use some type of circuit protection, mounted as close to the power source as possible. Fuses, breakers, or fusible links all work, just be sure to use something.
  4. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    I used a 30 amp breaker when I ran my IROC fan on my TPI motor............gotta have some type of fuse/breaker.
  5. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    Always try to use a circuit breaker instead of a fuse. The high initial current required to start the fan spinning, may blow a fuse that is rated higher than the actual running current. I had a situation with a Mustang fan that drew under 20 amps while running, but blows a 30A fuse on start up. A 30A circuit breaker works fine in this application.
