fuses popping when going into overdrive?
Discussion in 'The Garage' started by flatline, Feb 16, 2005.
  1. flatline
    flatline 1/2 ton status
    Sep 9, 2004
    167
    Cincinnati, Ohio (area)
    I just put in new fuses in everything today and when I took off down the road, I was listening to the radio and when it went from (D) to (OD) the fuse for the radio popped, this was a 30amp fuse!
    I changed the fuse and went down the road again, and it did it again when shifting to OD. So I changed it again and keep the selector in D and everything was fine.... So my question is why is this doing this only in OverDrive?
    Trans is a 700R4, I looked for disconnected wires and found none, is there something wrong with my electrical system or is the truck surging while it shifts, either way this is not good, I have to have my radio.
    * if anyone can help me out on this I would appreciate it.
  2. flatline
    Sep 9, 2004
    167
    anyone ?
  3. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    that would most likley be your torque converter lock up causing that
  4. dyeager535
    26,975
    Only thing I can think of is that it's a pressure switch that is screwed up, and grounding out inside the case. Lockup isn't a 4th only setup, so that shouldn't be the cause.
    I would think disconnecting the connector on the drivers side of the trans, and checking the wires for a short to ground would be the first step. Since it only happens going into OD, leaving the connector unplugged, and going out and driving it will probably show that the problem is gone. Don't leave it unplugged, but it's a valid test procedure.
  5. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    will it pop if you have it in od to start with?
  6. flatline
    Sep 9, 2004
    167
    No, it only pops when shifting to OverDrive, it doesn't do it any other time. I will try to locate the ground, as I found another one on the interior light today.
    question: is the interior/cargo light wired to the same fuse as the clock?
  7. Hobbes9112
    Hobbes9112 Registered Member
    Feb 20, 2005
    78
    Bonner Springs, KS
    My 85 Jimmy is doing the same thing. Did you ever get the problem figured out?
    Thanks!
    Brian
  8. dyeager535
    26,975
    If you don't get a response, pull the plug on the tranny, and go get it into OD. It's a 100% repeatable problem I assume, should reveal itself quickly if the problem is in the tranny or wiring to it, which it has to be I guess.
