Fvckitall
Discussion in 'The Garage' started by 4xcrazy, Apr 16, 2007.
  1. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    It should bolt right up if not you can take the rez off and put it on your pump. You have to remove the pulley to change the brackets anyhow. Or you can just remove the rez and install on your pump without removing the pulley. A seal kit is only about $10 to reseal it while it is apart also.
    Ira
  3. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    Donno what you mean about triangular style, but every PS pump I've dealt with, 350sbc, 400sbc, 6.2 dizzle, and 454bbc, are interchangeable.
    Brackets will be engine-specific, but the pumps will switch.
    -- A
  4. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    are you sure, I thought the flexplates had 2 different sets of holes.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Thats what I thouhgt too . th350 and th40 were the same flexplate . Some just had bolts into welded nuts on the converter , and some just had nut and bolts through hole tabs on the converter :dunno:
  6. Jason4x4
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    Hijack on, I like your repair on your taillight paul, if you want the one on my burb it is all yours, of course I need to check to see if it's good first. Hijack off
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well I kept looking online , and all th350 and th400 converters I saw were interchangable into the tranny .
    Your flexplate sucks . I have a stack here , maybe one with dual holes is around .
  8. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    There are flexplates that only have one set of convertor holes. Obviously, you were the unlucky person to have one and need the opposite.
  9. Jason4x4
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    well, you are actually further along than 24 hrs ago, since now you can attach the 2 together, and remember, if you want to work something out on this engine in my burb, let me know.
  10. Jason4x4
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    that looks purty.
