FYI, Stuff I found on eBay, NOS Steering Column, Axle Housing and K5 Quarter
Discussion in 'The Garage' started by 73k5blazer, Dec 11, 2006.
  1. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Just in case anybody looking for this stuff, here's a couple of interesting items I found while I was looking for other things:
    NOS 12Bolt housing: Clicky
    NOS K5 Quarter Panel, Real GM Metal: Clicky
    NOS Tilt Auto Steering Column: Clicky
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    What's with people not accepting paypal these days? I'm confused...
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    They don't like the fees.
  4. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    That why I always add 3 dollars to each purchase. One guy gave me a set of tow hooks cause I did it too. :D
  5. dyeager535
    26,982
    191
    FYI that isn't a 10 bolt housing.
    Don't know my 12 bolts well, but I'm assuming they were 8.8" ring gears (or whatever he listed) and that's what it is.
    Don't want anyone to bid on that and be disappointed. Not like anyone needs a bare 12 bolt rear truck housing either though I can't imagine. :)
  6. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Just a thought, but if someone needs one and you guys look real hard, there are 3 complete 10 bolt fronts for sale on Surplus Center. ;)
  7. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    My mistake. Sorry. I fixed it. I hadn't had my coffee yet.
  8. tcoker79
    tcoker79 Registered Member
    Feb 16, 2006
    38
    Creedmoor, NC, USA
    Would that column bolt into my 78 Blazer automatic, or what would it take?
  9. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    It will bolt in, turn signal switch is a bit different (longer style) you can buy a conversion thing from Painless for that, wipers will need new motor/control box if you want to use the column wiper switch, otherwise you could just leave your dash mounted switch. Dimmer switch will need moved to the column (connector fits, might need to lengthen it a bit) But other than that, I believe it will bolt right in.
  10. tcoker79
    Feb 16, 2006
    38
    Creedmoor, NC, USA
    "It will bolt in, turn signal switch is a bit different (longer style) you can buy a conversion thing from Painless for that, wipers will need new motor/control box if you want to use the column wiper switch" -- Could someone please elaborate on this information. Like what do I need to order from Painless and do I just need the wiper motor, what else might I need? Difficulty level?
