G.m 10 bolt vs ford 8.8
Discussion in 'The Garage' started by chevyk5blazer666, Jul 8, 2005.
  1. chevyk5blazer666
    chevyk5blazer666 Registered Member
    Jul 6, 2005
    44
    N.J.
    is the g.m 10 bolt just as s**ty as the ford 8.8? b/c the ford 8.8 sucks a big one i went thru three of them in my bronco . and i dont want to have the same problum with my blazer . is there a chevy axel like the ford 9 in. sorry stupid qustion
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    The GM 8.5" 10 bolt does not even rate as high on the P.O.S. chart as the 8.8" Ford axle ...... :laugh:
    The 9.5" axle is fairly strong but it still retains the shafts with c-clips.
    Tom
  3. chevyk5blazer666
    Jul 6, 2005
    44
    N.J.
    lol that waz funny .....but it dose anser my queastion....thanx .will a rear out of a c-30 pick up fit in my blazer ? (dully)
  4. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    I guess I should have been more specific. The semi-floater 9.5" GM rear end is comparable to the Ford 9" strength wise but it is not sought after like the 9" inch for many reasons and one of them is the axle shaft retention method.
    Yes a C-30 rear axle will fit in your Blazer if you are willing to deal with the wheel mount surface width issues and re-locate the spring pad perches and maybe the shock brackets .
    What year C-30 are you talking about ???
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    In all honesty, Find a K20 that you can get the axles from. A K30 would be better, but very hard too come by at a reasonable price.
  6. chevyk5blazer666
    Jul 6, 2005
    44
    N.J.
    ita a 1983 c-30 4wd with a dull rear 350 3 spd manual that is all i know snow plow cracked frame and it is in my yard
  7. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    The rear end doesnt matter if its 4x4 or not...
  8. chevyk5blazer666
    Jul 6, 2005
    44
    N.J.
    yah i kno but if the gears arnt the same im gonna take the front 2
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I know, but if ya get both axles from a K20, then you don't run into the miss matched gears problem.
  10. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    If it is a 4wd then it is a K-30. C-30's are 2wd's. It would also have a Dana 60 front axel.
  11. chevyk5blazer666
    Jul 6, 2005
    44
    N.J.
    but i dont have a k20 i have a c-30 thats free
  12. chevyk5blazer666
    Jul 6, 2005
    44
    N.J.
    then i gess someone converted it b/c the titel says c-30 and the vin maches and on the fender it says c-30
