G-Tech Pro?
Discussion in 'The Garage' started by CHEVY 4WD, Jan 31, 2004.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I never really though to much about them, but at my local speed shop they had one out for me to play with /forums/images/graemlins/grin.gif and its pretty cool they have a new one thats $250 it measures alot of stuff and I no idea how because the only wire is 1 to ur lighter... I know its probably not a "offroad" thing but has anyone used these? Im thinking about getting one
  2. dyeager535
    26,980
    As long as te conditions are ideal (perfectly flat surface to play on) they seem to be pretty accurate.
    I think it was BFG that was giving them away if you bought 4 tires or something like that. Been about 2 years though.
  3. Judd
    Judd 1/2 ton status
    Sep 27, 2002
    175
    N.E. Ga
    I have the older version and as the other feller said, it's decently accurate if all the variables are correct. I have made several 1/4 mile passes at the strip with the G-Tech on board and it's close but not perfect.
    For 1/4 numbers, you have to have the unit leveled right and make your runs on a flat surface {even better, make at least 2 or 3 runs in both direction and average}. Also, tire spin tends to make the results more suspect.
    The MPH is always off. The reason is that the G-Tech measures mph at exactly the 1/4 mile mark. At the strip, they average mph over the last 100ft or so {can't remember for sure} so there is no way the two mph numbers are going to be the same. Most of the time, the G-tech is around 2-3 mph off.
    ET can be pretty good if the unit is adjusted right {maybe a couple of tenths off}.
    Horsepower can also be close if you input the correct weight of the vehicle {has to be exact, close won't cut it}. I made some runs with my Firebird when it was stock. It came up with around 300 HP, my Kia rio chimmed in at 80HP /forums/images/graemlins/bow.gif, the 85 Mustang 5.0 came in at 175 HP. Remember, these are rear wheel numbers. Pretty dern close! At least within 20 horses or so.
    As I said, I have the older version that can be bought for around a 100 bucks or so. The new version should be better. Heck, it even has a shift light, built in tach and you no longer have to level the unit.
