Gabriel shocks for K30 with 4" of lift----SPECS
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 73k10sub, Jan 6, 2003.
  1. 73k10sub
    73k10sub 1/2 ton status
    Jul 23, 2001
    223
    Tulsa, OK
    Gabriel shocks for K30 with 4\" of lift----SPECS
    Called the local Pep Boys and inquired about shock options for the K30. This is what we came up with for an 86 K30 with 4" of lift:
    This is supposedly a Gabrial part number but I searched for it on Gabriel's website and found nothing.
    T60065-rear
    extended-29.73"
    compressed-17.45"
    stroke-12.28"
    T60064-front
    extended-23.23"
    compressed-13.95"
    stroke-9.28"
    They are listed as Pro Ryder Premium Gas shocks *suppossedly have Velocity Sensitive Technology (VST)*
    They are $19.99 each plus $10 S&H to get them in town.
    Our K30 has 4" springs with a ORD shackle flip and ORD zero rates all around. Would this be a good shock? Have any of you guys run these shocks?
  2. 73k10sub
    Jul 23, 2001
    223
    Tulsa, OK
    Re: Gabriel shocks for K30 with 4\" of lift----SPECS
    ttt
    Anybody got a feel for this? Gabriel's tech guy says they don't offer any extended length shocks. A previous post on this forum said they were available. ?????????????????
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If you call gabriel they will tell you they don't have an application for a 4" lifted K30. The reason is they manufacture shocks not kits.
    The guy at the parts store either has a software that has the options for a search or did the math himself.
    I used to take measurements and then go to the monroe dealer and look in the catalogs to find what I need, including length, damping rate and mounting configurations.
  4. mudrunner78
    mudrunner78 1/2 ton status
    Sep 7, 2001
    366
    Rocksprings, TX
    I am not at home right now but I found at autozone a gabriel shock with the same specs as the t60065, that you posted I can't remember the part number thou, let me see if a search will help. jesse
