gabriel shocks
Discussion in 'The Garage' started by chubbynova, Apr 25, 2006.
  1. chubbynova
    chubbynova Registered Member
    Oct 26, 2005
    77
    Cypress Tx
    i have searched and found part # g63438 for autozone gabriel shocks. i beleive it said they had 12.5 inches of travel and were being used for about 4 inches of lift. i currently have 4 in procomp front springs and 4 in block in back. i carry alot of stuff in the rear of my blazer and hardly get a chance to take the top off, so my rear sits significantly lower than the front. i recently bought some 6 in bds spring for the rear to replace the blocks and hopefully level it out. i was thinking i would replace all four shocks well i was installing the new springs. will these shock be long enough or do i need a different part #? they will be going on 77 if that matter. any help or recommendations would be appreciated.
  2. chubbynova
    Oct 26, 2005
    77
    Cypress Tx
    also the truck is mostly driven on the street and trails. i was thinking about adding a longer shackle or zero rate in the front if it ends up sitting way to high in the rear too.
  3. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    I run the Gabrial shocks all around and the rear is long enough.It's like a six inch lift because my shock mounts are 2'' lower than the stock axle,and I have a 4'' lift.If your running a 14 bolt ff with 6'' of lift I don't think they would work.
