Gallons Per Mile, Post up or die!
Discussion in 'The Garage' started by hawkeye649, Oct 13, 2004.
  1. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    Okay, here's the rules:
    Please post the specs on your rig in non-enigma code. I am getting better at reading the cryptic signatures, but I'm not 100%. Even better, just copy the format that I'm using to list my specifications /forums/images/graemlins/thumb.gif
    Anything that you think wll effect gas millage, please list. IE, ejector seats probably wont, but non-stock timing might.
    Because I'm lazy and closed minded, please no metric readings /forums/images/graemlins/whistling.gif
    1990 GMC F/S Jimmy /forums/images/graemlins/k5.gif
    350CUI TBI
    6* BTDC
    Lager-than-stock Air Filter
    Run 89 o-tang (the fruity drink w/ a kick) always.
    130,000K
    TH700R4
    20K-30K old rebuild.
    NP241
    No rebuild as far as I know
    Front and rear 10b
    3.73, open carriers.
    31x10x16 generic "all terain" tires. Really flat, really square, I.E. for the road.
    16MPG mixed backroads and highway with front hubs locked, in 2HI.
    Why do I ask? I'm trying to weigh all pros and cons of what lift situations I am thinking of....
  2. Sidepipes
    Sidepipes 1/2 ton status
    Nov 9, 2002
    139
    St. Thomas, Ontario, Canada
    14MPG
    Stock drivetrain( engine 150K KM's, rebuilt tranny and 10B with 3.42's)
    33" BFG AT's
    When I bought it it was pulling 8MPG with the Puny 235/75r15's and no convertor lockup..... lots of tuning and maintenance have gotten her up to 14MPG
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    1983 chevy k20
    350CUI g jet carb
    6* BTDC
    open element air filter
    Run 87 o-tang
    130k on truck
    TH700R4 in drive
    9k on rebuilt motor
    NP208
    4" suspention lift
    Front 10b and rear 14bsf
    3.42, gov loc rear open front
    35x12.5x15 cooper SST front, dunlop mud rover rear
    10MPG highway loaded or unoaded with speedo off (milage off also)
  4. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    1967 gmc lwb 1990- 454 stock rebuild -edelbrock 750 carb-holley street dominator intake- edelbrock performer cam-msd dist 7" suspension lift th400-np208-3/4 ton axles 4:10 gears 35/12.5/16.5 bfg's 5-6 mpg but all 4 tires smoke!!! /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    18+ mpg typical highway.
    Approx 450 hp & 750 ft/lbs
    Sub 15 second 1/4 mile times.
    33" Dueler ATs with no lift.
    7500 lbs curb weight.
    13-15 mpg Loaded to GVW of approx 15,000
    Range of almost 1000 miles between fuel stops on the interstate.
    Want to know more? /forums/images/graemlins/whistling.gif
    2002 DMax/Allison 2500HD loaded Silverado Crew Cab 4x4.
    Stock except for 60 gallon tank and chip.
  6. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    14 miles per imperial gallon or US gallon? /forums/images/graemlins/ears.gif
    Imperial Gallon is 4.54 liters
    US gallon is 3.78 liters.
    My spec's:
    1981 GMC F/S Jimmy
    6.2 diesel
    stock Air Filter
    Run whatever blend of diesel happens to be at the pumps
    230,000K
    SM 465
    200K-300K old
    NP 205
    D60, 14 FF
    4.56:1, open front, Detroit rear
    39.5x15x15 Swamper TSL's. I.E. suck for the road.
    16.3 miles per US gallon. /forums/images/graemlins/waytogo.gif
    Rene
  7. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    No but I would like to know more about the truggy. Are there any kind of gassoline considerations on trail-only rigs? Mines going to be a DD too, so just like every other souse I'm looking for a good harmony.
  8. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    howbout a duramax trailrig article? anyone /forums/images/graemlins/dunno.gif
  9. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    The 6.2 wasn't much in the go department, but got the gas millage.
    I always wondered why more people don't run diesels off road. Easier to water proof, and torque!!!
  10. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    85 K5.
    2" Body lift
    10 bolts, rear gov-bomb
    3.73 gears.
    Q78 TSL's (~36" tall)
    700R4 w/shift kit
    6.2 diesel-220K miles
    -Rebuilt pump, fuel screw increased to much
    -6.5 Injectors
    -J-code intake
    Heavy right foot.
    average mpg=20.
    same setup with 33" BFG radials that measure 31.5"- average MPG=23-24.
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Nothing for the truggy. I kept it basically stock using off-the-shelf parts for easy repair and it will run fine on any automotive grade gasoline I can find anywhere. The TBI computer even compensates for altitude changes. That's nice considering I may go from sea level to 8k+ elevation from one trip to the next. I don't need or want tons of power, the stock TBI does just fine, what I do want is easy servicing with cheap parts and as robust as possible. Now if I can just get my suspension to be as robust as the drive train has been...
    DMax/Alli trail rig? Not till they get MUCH cheaper, and they are not light or small...
  12. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    1979 Chevy 1/2 4x4 pickup
    406 CI 4-barrel, Edelbrock intake, headers, 3" flowmaster, MSD Ignition, Accel 300+ wires, 14" x 6" K&N Air Filter at 10* BTDC
    10K old rebuild.
    Run 87 o-tang for street, 91 o-tang for trails
    120,000K
    TH350
    3K old rebuild.
    NP203
    5K old rebuild.
    Front Dana 44 and rear 14bff
    3.73 gears, front posi, rear locked
    35x12.50x15 BFG Baja TA's (speedo is off)
    8 MPG with street driving/freeways in 2HI.
    2 MPG in 4LO romping on it in the dunes /forums/images/graemlins/peace.gif
    I have worn 36" swampers that I'll run for dunes from now on, and am going to get a cam like rfguitar eventually. /forums/images/graemlins/truck.gif
  13. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Plus weight, smell, mess (common), and noise. /forums/images/graemlins/laugh.gif But I gotta say, Rene's was nicely done and I had no problems with it on the trail (smell, noise, etc.). It worked very well IMO. If I were doing a daily driver with mpg and longevity concerns with solid off-road capability, I would probably be looking for a turbo 6.2/6.5.
  14. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    ... I am getting better at reading the cryptic signatures....
    350QKN70020845635:11 /forums/images/graemlins/tongue.gif /forums/images/graemlins/cool.gif
  15. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    350 5k miles or so
    Cam, 15" vaccuum
    quadrajunk
    Performer, HEI
    Dual exhaust
    K&N
    8*
    NV4500
    14" lift
    4.10s
    38" Radials
    12 MPG
    Dont know how much it has increased after I did the TPI, for now ill estimate 14-15MPG.
  16. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    350 w/ quadrajet
    K&N(crap)
    TH700R4
    NP208
    4563???
    5.11's maybe...? /forums/images/graemlins/1zhelp.gif
  17. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    How can you have a quadrajet (nice off-road & onroad carb) and TPi? I can't remember what it stands for exactly, but I'm about 90% sure it's a form of fuel inFection...
  18. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    1971 Chevy Blazer /forums/images/graemlins/k5.gif
    400 CID Small Block Chevy
    HEI with vacuum advance
    Stock Q-jet with choke wired open
    14x4" K&N open element w/ pre-filter
    Always use 87 octaine
    130,000 miles
    TH350 trans rebuilt by me
    NP205 T-case No rebuild as far as I know
    D44/14BFF 4.56 open/welded.
    36" TSL bias ply's on 15x10 wheels run at about 25psi on the street (when I remember to fill them).
    Soft top /forums/images/graemlins/thumb.gif
    8MPG hwy going 70mph Doubled it once following my budy's toy that has trouble going 55mph.
    Got 12mpg with 1/2 ton axles and 3.73 gears.
  19. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    1972 chevy blazer
    427 Tall Deck Holley carb.
    8" susp. lift (the other 10" is body lift and dropped spring hangers)
    Stock 14"x5" air cleaner
    87 Octane
    75,000
    was a TH350
    NP205
    Dana 60 & 14 bolt Full Floater,
    4.56 & Detroits
    44" ground hawgs ( they really measure 41")
    10-12 MPG
  20. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    456 gears 35 tires and 11 mpg
