garage cleaning sale
Discussion in 'General Parts for Sale' started by 1-tonmudder, Aug 20, 2006.
  1. 1-tonmudder
    1-tonmudder 1/2 ton status
    Apr 24, 2005
    3,052
    In a junkyard somewhere
    I have the following parts for sale.
    Th400/Dana 20 adapter with bullgear $200
    Th400/Dana 20 drive sleeve little pitted but good splines $40
    J-truck T-176 "long" input bearing ret. $25
    J-truck T-176 bellhousing spacer $40
    T-18 shifter caps $50
    T-18 bullgears $35
    T-18 bellhousing spacer $40
    Jeep NT Dana 44 rear 3:73 with trak-lok $250
    Various T-18 gears and bare cases.
    74 J-20 Dana 44 8lug drive flange front with flat top's complete hub to hub 3:73 gear $250
    360/TH400/Quadratrac for parts
    AMC 360 engine,runs but smoke,complete with all accessories. $150
    A904/Dana 300 adapter $50
    T-176/Dana 300 adapter $100
    T-176 bare case,no broken ears $40
    Dana 44 drive flanges $40 a set
    Early style V-8(AMC) PS pulleys $20
    Early Waggy motor to trans adapter,not sure if Buick or AMC $75
    A/C bracket and pulleys for AMC V8 $40
    Chevy SM465/NP205 adapter with sleeve $125
    Chevy SM465/NP205 drive sleeve only $50
    Chevy TH350/NP208 adapter $75
    Chevy Th350/NP205 drive sleeve(early style) with center support bearing $50
    Chevy TH400 bare case 4wd version $100
    Chevy SM465 shifter caps $50
    Chevy SM465 shifter $35
    Chevy SM465 bare cases $35
    Chevy SM465 various shafts,gears.
    Chevy TB exhaust manifolds with air tubes $50
    Chevy 454 TB to spreadbore(Quadrajet)adapter plate will work on SBC or BBC $50
    4 6-lug 15X8 Chevy ralleys with centers and ring's $150
    Various Dana 60 front shafts(no 78-79 Fords)$75 ea
    Ford NP435/NP205 adapter $50
    Ford C6/NP 203 adapter $50
    Ford T-19 6.32:1 first from 84 F-350 4wd with 6.9 diesel $300
    Scout T-19 with shifter and bullgear $250
    Scout T-18 with shifter and bullgear $250
    Dodge NP203 rangebox $100
    Dana 70 center section's,new old stock with caps, never had tubes pressed into them $100
    Dodge/Chevy Dana 60 front spindles $75 ea
    Various NP205 gears,cases,shafts,shift rails,and forks
    Dana 60 front automatic locking hubs,one is good one for parts $50
    Chevy/Dodge Dana 60 front caliper mounts $50 ea
    Ford/Chevy/Dodge DRW Dana 60 front hubs $75 ea
    Dodge Dana 60 front SRW hubs for ext selecto's $100 ea
    Dodge/Chevy Dana 60 calipers $40 a set
    Jeep Dana 20 to Chevy M21(car 4 speed) adapter by AA $75
    Chevy/Dodge Dana 60 Caliper mount's 2 rights .$50 ea
    Dust sheilds for Chevy/Dodge Dan 60 front $25.
    Ford T-19/BW1340 adapter $100
    EB 3spd/Dana 20 adapter with bullgear $75
    More stuff laying around,but this is all I can remeber right now.Parts are located in Greneville,TN and prices are plus shipping.
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Boy, you got a lot of crap!
  3. 1-tonmudder
    Apr 24, 2005
    3,052
    Yes sir I do.The bad parts is that this is just what I could remember in about 5 min.Dont you need some of this stuff,I want your 400/205 adapter:D
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    I replied to your post in my thread.
  5. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    I'll go $40 shipped for the Dodge D60 front spring plates.
    Jimbo
  6. 1-tonmudder
    Apr 24, 2005
    3,052
    Show me the money:D
  7. Jimbo*
    Mar 8, 2005
    1,420
    roswell, new mexico
    Money has been shown.
    Thanks, Jimbo
  8. 1-tonmudder
    Apr 24, 2005
    3,052
  9. dabears73k5
    dabears73k5 Registered Member
    Jul 27, 2005
    52
    El Segundo, CA
    the bare dana 60 housing u got a pic? and are you willing to ship?
  10. hatchetjack
    hatchetjack Registered Member
    Feb 13, 2004
    28
    LA (lower Alabama)
    I could be interested in the t-18/d20 combo if you still have it?
  11. 1-tonmudder
    Apr 24, 2005
    3,052
    yeah i still have it
  12. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    Hey... anyway of making a deal for a set of chevy d60 caliper brackets...? need anything?
  13. howardjnl
    howardjnl Registered Member
    Jan 2, 2007
    23
    VA
    If you still have it, I'm interested in the Dodge NP435 to NP208 adapter.
    John
  14. 1-tonmudder
    Apr 24, 2005
    3,052
    It's already gone,but I might be able to come up with another one.
  15. howardjnl
    Jan 2, 2007
    23
    VA
    Let me explain my situation first:
    I have a Dodge 2wd NP435 that I want to reuse as a Dodge 4x4 NP435 by changing out the output shaft and rear adapter / tailhousing. I've discovered that the bolt pattern on the rear of a Dodge NP435 is "square" for 2wd and "trapezoidal" for 4wd. But Ford used "square" bolt pattern for 4wd.
    I'm faced with two choices:
    1. Obtain a whole Dodge 4wd NP435 equipped for NP208 or NP241 xfer case, OR
    2. Obtain a FORD NP435 tailhousing for NP208 and a Dodge output shaft and fit them to my current Dodge 2wd NP435 (interesting, huh?).
    So, I think I cannot use the Dodge NP435 to NP208 adapter I originally asked about. But I could use help with doing either of the choices above.
    John
  16. 1-tonmudder
    Apr 24, 2005
    3,052
    Here's what I have.
    2 4wd dodge 435's,one is bad and I could get the shaft out of.
    1 core Ford 435 that I could pull the shaft out of also.
    And I should also have the ford 435/208 adapter.So just tell me which way to want to go.:D
  17. howardjnl
    Jan 2, 2007
    23
    VA
    Cool. I'm interested in the output / tail shaft from the bad Dodge 4wd 435, and the Ford 435/208 adapter.
    This is a challenge I'd like to take on, "cross breeding" a '78 Dodge engine and transmission with a Ford adapter in an '88 Dodge truck.
    Please let me know if/when you might be able to get around to this, and what you'd like for these ($).
    John
  18. 1-tonmudder
    Apr 24, 2005
    3,052
    Updated list.
  19. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    Are the dust shields the large ones on the inboard side of the rotor or the little things that attached to the axle shaft aka "slingers"?
    If they are the large shields, hows $25 shipped?
    Thx
  20. 1-tonmudder
    Apr 24, 2005
    3,052
    Both,that's why they are $25.
