Garage door keypad resetting
Discussion in 'The Garage' started by 90K5, Oct 15, 2006.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Any garage door guys in here? got a Genie, no model number i could see, probably 8-10 years old. I need to set a code, but dont have the old one...thanks
  2. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    If it's a genie, there may be a box on the side of the garage opener mounted to the ceiling that has your code for the opener... If it's a code hopper model then you need to program the remote with your reciever..... You should find a plate attached to the opener that will give you your model type or post a pic and someone may have the same type and tell you what kind of remote you need
  3. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    I have a genie of a similar genre to yours, judging by age anyway. To reprogram the opener for the new remotes I bought there was a button on the opener under the light cover. When pressed there was a small red light that would flash for a couple seconds. during that time you had to mash the button on your remote and that would set the opener to that remote. The button on the opener wasnt labled, I was just messing around with it oneday and it worked.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I have a remote that works, but theres a keypad outside the garage door that i dont know the code to, and want to program it. The opener itself isnt even a Genie, think its a Chamberlain...only the keypad is Genie
  5. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
  6. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    well, that looks like mine, but couldnt get it to work
  8. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Ok so it's a wired Opener then you most likely have a broken lead wire.... I havne't installed one on mine yet.... keep needing to since I don't have enough remotes for all my vehicles.....
