garage floor ?
Discussion in 'The Garage' started by riz, May 9, 2002.
  1. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=blue>How do I clean the floor of my garage and what can I put on it to help keep it clean ? I'd like to get rid of all the oil stains and such that has gotten on there over the years.
  2. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I know some of those handcleaners work. You can also use laundry detergent.
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    After leaving oil on a garage floor long enough, it stains deep. Diesel is a great solvent for surface stains and getting up fresh oil (really efficient at it) but after that I keep resorting to my sand blaster. It doesnt pit it and restores the good look.
  4. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    I'm getting ready to clean my shop floor first with solvent and then with some acid. Then I am going to paint it with an epoxy paint designed for concrete floors. You can buy the paint at most hardware stores.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Start with some Oil-Dri. Use a brick to grind it into powder, directly on the oil stains. Let it sit overnight. Then brush it off with a stiff bristle broom. That will take off an amazing amount of the stain without any chemicals. If you still want to get more of it off, there are some heavy duty driveway degreasers available at many hardware stores.
    The epoxy concrete paint can make cleanup much easier in the future, but it will cost $200 and up to do a 2-car garage.
  6. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    And after you seal the floor, be careful. Any spill will be real slippery even plain water.
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I'v always used gasoline, Tide, and water. Scrub it all around with a good stiff broom It works great. Then seal or paint it.
  8. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Mauric Acid sp? will work on spots. Wouldn't suggest whole floor due to fumes and wipe-up.
  9. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Every couple months, I use revive-a-drive on the street where I park. It does a better job the longer I let it soak, which isn't usually too long.
  10. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    My garage floor is epoxy painted, and a cool trick i use since my hot water heater is located in the garage, Use the drain spigot on it for a supply of hot water, and I use TIDE laundry det. to clean also.
  11. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Well riz we use some heavy duty stuff from Zep on our shop floors. It works great. If you want some I could probably pass a couple cups your way. The old deep in stuff will need more then even that stuff can do. I would look into Muricacid. That teamed with a pressure washer seems to work the best
  12. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    I know there are a lot of people that could care less, which shouldnt be the case. Remember all that stuff you "clean" your floor with, probably some bad chemicals, ends up getting washed down the drive way and into the ground water evantually /forums/images/icons/frown.gif That said, n the upside, doing like Harry said (i think) taking floor dry and grinding it in with a board or something does suprisingly well, especially if you dont let the stains sit too long. /forums/images/icons/smile.gif
  13. trukman1
    trukman1 1/2 ton status
    Mar 5, 2002
    129
    Ohio
    riz, you might want to look at the site www.doityourself.com/brick/concrete for some ideas. Remember to be really cautious if you use muratic acid...eye protection and rubber boots/gloves. Also, if it washes out across your cement driveway it may erode the top finish. Good luck.
  14. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    thank you.
    as i read some of these suggestions that was running through my mind.
    diesel fuel is thin oil so I cant see that helping too much, also the huge stain where I fuel my truck points against that plan.
    gasoline is a very poor replacement for a solvent at the best of times and contains a bunch of stuff that shouldnt be released into the air, kinda why your gas cap is now sealed.
