Gas Cap Problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ZfromNJ, Feb 5, 2001.
  1. ZfromNJ
    ZfromNJ Registered Member
    Jan 26, 2001
    99
    New Jersey
    I am having gas cap problems because the area that my gas cap connects to is all worn out and the cap does not stay. All it does is spin in the given area and does not seal up the pressure needed. Any suggestions?
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    If I am not mistaken, I think that area is unboltable. You could just go get a new piece for in there and a new tank filler tube. You may be able o get away with just buying the filler tube if it just slides threw the boltable area mentioned above.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Look closely at the filler neck to see what's damaged. The cap on my '75 didn't want to stay tight until I bent the filler neck back into the correct shape. The locking tangs had gotten out of shape over the years. The cap stays on fine now.
  4. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Also check the cap and make sure it is in good shape. Mine was just spinning around and I had to replace the Cap itself.
    Good luck!
    C'moe
    <font color=black>the blazer is "Back in Black"
  5. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Hey man, the filler neck is just a metal piece that will come off with a screwdriver and a 3/8" socket. Take it off and get one from a junkyard. Easy as pie. :)
    -- Mike
