Gas filler neck problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Jun 25, 2001.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I am trying to hook up the saddle tanks in my pickup. The problem I have is that the filler neck itself (that attaches to the bed) uses a hose that is 1-7/8 or 1-15/16th ID. The gas tank itself takes a hose of 1-1/2 ID. If it matters, the tanks are from a 73 - 79, and the bed and filler necks are from an 87.
    You guys are pretty ingenuitive; what can I use to connect the tanks?
    -- Mike
  2. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    My first guess would be to get somekind of a reducer maybe peace of PVC pipe would work if the gas won't eat it up.
    Hope this helps out some. Cethern
    Lost? i'm not lost i'm just disorienated
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just use the bigger hose and put a hose clamp on it and tighten the @#$!@ out of it. I'm sure it'll work fine, it's rubber hose.
    Tim
  4. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    It's pretty thick rubber, double wall. I guess I can try it.
    -- Mike
  5. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Malke sure it specifically says for fuel and oil! They're a little more expensive ($1 or $2), but the standard hose will disintegrate quick when used with petroleum based liquids, especially gasoline and gas vapors.
    Ratch
    **<A target="_blank" HREF=http://k5.8m.com>http://k5.8m.com</A> What more is there to life?**
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    Go to your local exhaust shop and have the make a reducer out of Stainless. Shouldn't be very expensive and then use the 1 1/2" on the tank side and the smaller stuff on the other side.
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://www.geocities.com/emmettology101>http://www.geocities.com/emmettology101</A>
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That would work better.
    Tim
  8. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Emmettology, that sounds like an idea. Thanks for the heads up!
    -- Mike
