Gas Filler Tube
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by LAZYMON, Aug 28, 2000.
  1. LAZYMON
    LAZYMON 1/2 ton status Premium Member
    Jul 26, 2000
    235
    Lake Tahoe
    Hey All
    I just bought my 73 Blazer and I went to put gas in it. The stations pump keeps shutting off because the neck was made for a regular nozzle. I tried two stations and same thing happens unless I keep the gas flow really slow. Is there a solution to this?
  2. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I have the same problem. I just assumed it was me being a retard.
    Brian
    84k5, 4"Skyjacker lift,33x12.5 Goodyear MT/R, 15x10 Bajas
  3. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    I don't have that problem with my '73. Check out your filler hose for obstructions or holes. Also look around for stations with different types of pumps.
  4. Jimmy1972
    Jimmy1972 Registered Member
    Aug 22, 2000
    17
    Redding, Ca
    Have the same problem on my 72. I found that if I angle the nozle just right it works fine.
  5. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
    tilt it up some or try pulling it out slightly. That's what I have to do for my '83, b/c the pumps always shut off way too early.Also if you roll back the plastic cup that goes over the whole mouth it won't shut off as quick. The pumps here will shut off after like $5, no way my truck is full hehe. Try $30
    -JoSH
    crazeebush@aol.com
    http://josh.coloradok5.com
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    My Jimmy was born as a Diesel and now is a 350, but I still have the large diesel opening for the filler and I have no problems at the pumps.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  7. Grim-Reaper
    7,385
    Atlanta
    I Have less problem with my 75 then I do with my 79 and my Supra. The fill neck on the 79 is recessed so they could put the door on the body and just that couple inches seems to make a big difference. Same pump I have trouble on that will fill the 75 no problem at all. On the 79 I have to pull it back some before it will fill without cutting off.
    These new vapor recovery pumps are plain fussy.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
