Gas Flood on TBI
Discussion in 'The Garage' started by letsrollusaf, May 25, 2006.
  1. letsrollusaf
    letsrollusaf Registered Member
    Jun 17, 2005
    30
    Whiteman AFB, MO
    Basically the problem is this....Every once in awhile i'll be driving and it will bog down real bad and want to die but it doesn't as long as i give it gas, a couple of times when I've come to a stop at a stop sign it dies instantly. Well I open the hood and it reeks of pure gas....i give it a minute to air out and I go to start it and nothing it cranks but no pushover.....i give it about 5 more minutes and then it starts up fine...when all of this happens the Check Engine light comes on and its spits out the code 15 for low coolant temp (not sure what that would have to do with anything like this, but it always kicks out when the truck dies or won't start with this problem) A little history on the truck, this only started happening when I put new headers on it from the stock manifold, i've been running it with open headers for a little bit. I've got the O2 sensor in on a collector but not sure its doing any good. Basically its just throwing too much fuel in....any advice or help?
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    sounds electrical to me
  3. BoondocK5
    BoondocK5 1 ton status Author
    May 13, 2006
    10,035
    63
    Salt Lake City, Utah
    first thing first, check for proper fuel pressure.
  4. 87350blaz
    87350blaz Registered Member
    Oct 23, 2005
    33
    New Mexico
    it maybe could be your o2 sensor. with open pipes and no back pressure might not get a good reading.
    or your throttle postion sensor. The fuel mixture leans out because the computer does not receive the right signal telling it to add fuel as the throttle opens. Eventually, the oxygen sensor senses the problem and adjusts the mixture, but not before the engine stumbles.
  5. dyeager535
    26,982
    191
    I say look up the code 15 and see what triggers it.
    Low engine temp (whether real or indicated) is going to flood the engine, it's equivalent to choking a carbureted engine when it's at operating temp.
  6. kwissman
    kwissman 1/2 ton status
    Jan 14, 2006
    118
    Austin, TX
    If your O2 sensor is mounted at the collector, you will need to upgrade to a 3 wire heated sensor. The sensor is too far from the combustion event and it does not get hot enough to operate correctly. I got my 3 wire NTK off ebay new for about 20 dollars I believe it was PN 293000 or something like that. All you have to do is run switched power to it and it will work.
  7. 84zz4ss
    84zz4ss 1/2 ton status Premium Member
    Dec 28, 2004
    1,342
    Pensacola FL
    Verify coolant temp sensor operation. False ect data will cause a rich condition.
  8. 87350blaz
    Oct 23, 2005
    33
    New Mexico
    do you have just one o2 sensor runing with open headers?
  9. letsrollusaf
    Jun 17, 2005
    30
    Whiteman AFB, MO
    Yea i just have the stock O2 sensor which looks extremely black, and the wire is pulled very taught at the collector.
  10. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    Replace your temp sending unit.
    As mentioned, if the ECM thinks it is -40F out (which a failed temp sensor will cause the ECM to think) it will choke the your engine big time and run super rich.
    Your 02 sensor is black becuase of the coolant temp sensor issue. The sensor is located at the front of the intake beside the thermostat housing, and has a 2 pin connector with a black wire and a yellow wire hooked up into it.
    The Temp sending unit has as much, if not more to do with your fuel calibrations than the 02 sensor does.
    As far as the 02 sensor goes, if you're running long tube headers, you'll probally need to get yourself a heated 02 sensor. Running open headers simply doesn't work at all, as the 02 sensor will be picking up atmosphere 02, and will big time make your truck rich as well. You can extend the purple wire on the 02 sensor if needed be, just don't touch the black wire that comes right off the 02 sensor itself, its a calibrated length.
  11. letsrollusaf
    Jun 17, 2005
    30
    Whiteman AFB, MO
    Well I believe I had made a rookie mistake by buying one of these "Speed" chips that have two wires on them and you hook it up to that temp sensor, well I only had it on for about a day or two when it really started running like ****, in any event the lines that I spliced into off that sensor (blak and yellow lines) were still open. Basically there was open wires on that temp sensors and black and yelllow wires, so i electrical taped over it.
  12. Russell
    Jun 23, 2000
    7,925
    337
    Them things are a crock, go ahead and hook the TPS back up and you'll be fine again :)
  13. letsrollusaf
    Jun 17, 2005
    30
    Whiteman AFB, MO
    As far as the temp sensor, does the connection side need replacing or the sensor itself embedded in the intake manifold? Also what does the heated sensor do that the regular O2 sensor does not and also are those lines usually long enough to reach collector? How hard is that one sensor anyways to change......
