gas gage not workin'. quick help!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rcknpimp, Nov 2, 2002.
  1. rcknpimp
    rcknpimp Registered Member
    Oct 27, 2002
    7
    Dexter, ,MI
    gas gage not workin\'. quick help!
    i started up my truck today, and its fairly cold out. and come to find the gas gage to read empty. i filled up last! and theres no gas on the ground. need to know how to fix it, or whats wrong. maybe just a stuck slider? i dunno how it works, didn't look into it yet.
  2. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Re: gas gage not workin\'. quick help!
    It's an electrical gauge right? Mine was and it quit working. The wire running to the back was frayed and touching ground. Fixed that right up and voila, gauge worked again. Might be your problem!
  3. mattyblazer
    mattyblazer 1/2 ton status
    Sep 22, 2002
    202
    Long Island, NY
    Mine says full until I have about 3 gallons left.
    Matt
  4. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    dude... easy fix
    Stop at every gas station you come to...
  5. GQ 350
    GQ 350 Registered Member
    Jul 20, 2002
    19
    Kelowna, British Columbia Canada
    /forums/images/graemlins/truck.gifOn my pick-up after I had dropped my tanks the one tank always read really full, so I used a long screw driver to tap the ground prong the gauge then worked fine.
    so to my point, check all your wires and even the fuse before you go and buy a new sender.
    /forums/images/graemlins/thumb.gifGood Luck with it /forums/images/graemlins/truck.gif
