Gas Gage problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1STK5, Oct 15, 2002.
  1. 1STK5
    1STK5 Registered Member
    Jan 31, 2002
    24
    AC,NJ
    Gas Gage won't register completely full, what can I do to correct the problem?
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Check the sending unit, It might be worn on the variable resister that sends the signal to the guage.
    Bill
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    You can also check the nuts that hold the gauge to the circuit tape behind the dash. If they become a little lose, can make the gauge read funny.
  4. dyeager535
    26,977
    If you've ever let it get really low, does it read the same amount under "E" that it does under "F"? (don't forget, GM typically put some "reserve" into the gauge reading)
    If someones monkeyed with the gauge, or the gauge itself is just "off" it can do that too.
    Mine never goes quite to "F", but I've never let it get so far down to tell where "E" really is.
  5. Chris87K5
    Chris87K5 1/2 ton status
    Sep 21, 2002
    322
    Pennsyltucky
    The baffle could be loose inside your tank causing the float to not work properly. I had this problem.
  6. mattyblazer
    mattyblazer 1/2 ton status
    Sep 22, 2002
    202
    Long Island, NY
    The guage in my 87' reads full until there is 5 gallons left, so I have to watch it and top off the tank all the time.
    Matt
  7. Chris87K5
    Sep 21, 2002
    322
    Pennsyltucky
    That is exactaly what mine did until I put a new sender in it and fixed the baffle.....I would say that the baffle is causing your problem.
  8. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    I put in a new sender and its still not reading over half!
    /forums/images/graemlins/angryfire.gif duno what it is... possibly the gauge but somtimes it reads past full!? I dont know beats me
