Gas Gauge Flakey
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jackson 88K5, Dec 1, 2000.
  1. Jackson 88K5
    Jackson 88K5 1/2 ton status
    Oct 27, 2000
    104
    Topsham, Maine, USA
    Tonight I was finishing some upgrades (manual hubs)[​IMG] and went for a test drive and after putting it in 4 WD and playing around a little off road I saw my gas gauge go past full then it stopped in the 3 o'clock postion WoW I wish I had that much gas in there, but I know I have only half a tank, what do you think could be wrong with the gauge of float?
    http://www.tjcommons.com/88K5/
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    try checking the ground and power wire at the sending unit mine did the exact same thing while i was wheeling and what happend was the power wire poped off it dose not atatch very well it only pushes on and is very easy to jar loose. hope this helps. good luck
    s.smith 77blazer lookin 4 mud
  3. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    I've heard that most guage problems are ground related. Maybe a wire got tweaked when you were playing around? Check the wires going to the sender.
    Rene
  4. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Hey Mudhog, looks like you beat me to it by less than a minute [​IMG], I guess great minds think alike![​IMG]
    Rene
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, the circuit is open somewhere. When the gauge circuit goes open on a GM, the gauge pegs past full. The problem is usually at or near where the wires attach to the top of the fuel tank. It's not a real easy area to get your hands into, but with a bit of work you can reach in there and check things out.
    http://ThunderTruck.ColoradoK5.com
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    very true trustyk5 very true lol
  7. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Try pulling the fuel gauge off and reinstalling it. Mine did the same thing and one of the prongs were not sitting the clip right and it wouldnt make a connection..easy fix. Try it before trouble shooting the wiring may save time
  8. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    It's called "VIRTUAL gas gauge".
    Mine fluctuates back and forth most of the time.. but it only fluctuates in 1/8 tank increments. Except when it's full it won't flicker until it goes down a little.
    (updated) http://www.rocko.coloradok5.com
  9. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I had a fuel guage that wandered all over the place. I fixed mine the same way mouse says.
    I had to pull my guage cluster to grease the speedo cable To get the cruse controll to work right. While I had everything apart I pulled the gas guage out of its sockets and cleaned up the connections. Been steady as a rock and working good ever sence.
