Gas Gauge is messed!
Discussion in 'The Garage' started by RustBuket, Jan 26, 2004.
  1. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Ever since I took my tank out to repair it, the gas gauge has been acting up. One moment it'll read correctly then another it jumps to over full. Is this a faulty ground wire? Power wire? Something else?
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
    sounds kinda like the signal wire
    one of mine does that(dual tanks)
    if no signal, the guage goes over to about the 3 oclock position
  3. RustBuket
    Feb 21, 2003
    1,618
    Is the signal wire the red wire that goes to the top of the tank??
  4. RustBuket
    Feb 21, 2003
    1,618
  5. dyeager535
    26,981
    What year? If not FI, you only have the black ground, and in all the rigs I've seen, a pink wire for the sender. But if it's red, and is the only wire except the ground coming from the top of the tank, thats going to be it.
  6. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    If your reading over the full mark (about 3 o'clock position) then you have an open somewhere. This is normally between the gauge and the sending unit (power side). The ground side is easy to check since it is a ground strap about a foot or so long.
