Gas Gauge is pretty screwed...
Discussion in 'The Garage' started by RustBuket, Feb 8, 2004.
  1. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Ok, so I put a hole in my tank and had to drop it/repair it/reinstall. After the reinstallation, the gas gauge is acting really weird. It jumps up to about the 3 oclock position sometimes and everytime I start my truck up I get a different reading so I don't know which is right! What wire did I not connect right? The red one that goes to the sender on top? Or is there another wire that I just didn't see all together? A ground maybe? /forums/images/graemlins/1zhelp.gif
  2. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    There is a ground that needs to be connected...it usually runs from the frame/crossmember in front of the tank to the ground tab on the sending unit.. if ya only hooked up opne wire then ya missed one...
  3. RustBuket
    Feb 21, 2003
    1,618
    Well then that is most likely my problem. And i bet the whats happening is the ground is bouncing off the tank and sort of making connections sometimes giving me the messed gauge...
  4. RustBuket
    Feb 21, 2003
    1,618
    Do I have to drop the tank to reattach the ground wire?
  5. RustBuket
    Feb 21, 2003
    1,618
  6. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    Pleaselet me know if that helps b/c i bought a 90 jimmy and it does the same thing. Sometimes it wont move sometimes it will. It jumps around to. And it moves every time I restart the truck. WTF??? /forums/images/graemlins/eek.gif
  7. husurddy
    husurddy 1/2 ton status
    Jul 28, 2001
    108
    Snow Hill, Maryland, go east \'till you hit water
    I had the same problem but it wasn't a wire. Mine turned out to be the plastic tub in the tank had come undone and was hitting my sending unit. Before I fixed it I would hear a slight banging noise in the tank when I first came to a stop. I used gas tank sealer on the nuts that press down and hold the tub in place and has worked great for two years.
