gas gauge is temper mental
Discussion in 'The Garage' started by the fall guy, Dec 14, 2004.
  1. the fall guy
    the fall guy Registered Member
    Jul 1, 2004
    35
    I have a 85 k5 siveraldo...just recently the gas gauge started to show empty when i started the truck and after a couple of smacks on the dash it started working again....just wondering if it's a bad conection or time for a new gauge?
    thanks
  2. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    Bad connection... not likely. A bad connection is going to give a full or 3 o'clock position on the guage.
    To read empty there has to be 0 ohms (grounded).
    I would lean towards a short to ground that is released when you beat on it or a bad guage.
  3. stizkidz
    stizkidz 1/2 ton status
    Nov 11, 2004
    219
    near Atlantic City, NJ
    Mine sucks too. When I fill the tank, the needle points to about 1/4 above full. After it reaches the 3/4 tank mark, it pretty much drops fast and I need to fill up again soon.
  4. hawk368
    hawk368 Registered Member
    Jul 29, 2004
    50
    White Salmon Wa.
    I watched mine as I filled up after barely getting to the station. I have the 31 gallon tank. But my gauge read full at 23 gallons on the pump. I know I was empty when I started because it took 31.5 gallons when topped off.
