gas gauge not working
Discussion in 'The Garage' started by Calclips, Aug 21, 2002.
  1. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    My gas gauge isn't working, how can I test to see if the sending unit is bad or if its the gauge... or if its the wiring between the sending unit and the gauge? Thanks alot for any help....
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Might want to reach up behind the dash and make sure the harness is plugged in tight. I had the same prob., turned out the harness came loose on one end.
    John
  3. Calclips
    Apr 4, 2001
    1,005
    Alright, I'll check that out and make sure everything is good and tight, does anyone know of a quick way to test the sending unit... can I check for voltage somewhere? Thanks alot.
  4. 19Jimmy87
    19Jimmy87 Registered Member
    May 9, 2002
    65
    Kalamazoo, Michigan
    Follow the wire under the truck. I did this and found my wire fell and was burnt apart by the exhaust pipe. I reattached the wires and it works great now. Also, when I asked a similar question, I was told that the sending unit rarely goes out.
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I had this problem also, mine was the 2 nuts that hold the gauge to the panel and circuit board came loose and wasn't getting connection, tightened them up and fixed the problem.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If the gauge is reading way past the full mark all the time, then there's an open circuit somewhere. Check the connector on the back of the cluster, the one at the sending unit and the ground at the tank.
    If the gauge is reading empty all the time, there's a short to ground in the wire that goes from the sending unit to the gauge.
    If the gauge is reading somewhere in the middle all the time, then either the sending unit is stuck or the gauge itself has died.
    GM fuel gauges will read full with 90 ohms of resistance in the circuit and empty at around 0 ohms. /forums/images/icons/cool.gif
  7. Calclips
    Apr 4, 2001
    1,005
    The gauge reads arround 1/4 tank.
  8. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Disconect the Pink wire from the gas tank and cheek the gauge. Did the gauge move? If it the same Spot it is befor the tank. If it moved then try gounding the wire and check the gauge it should go to the opposit side of the gauge. This would mean the sending unit is bad. Keep us informed on what was wrong.
  9. Calclips
    Apr 4, 2001
    1,005
    Ok, I'll try that when I go home tonight.
