Gas gauge not working?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1989k5, Mar 9, 2004.
  1. 1989k5
    1989k5 Registered Member
    Jun 10, 2003
    36
    near Lake Superior, Wisconsin
    This kind of seems petty, but I have not been able to get my gas gauge to work since I put my truck back together. 89 350 TBI/700r4. Before I tore the truck down it worked. The pump works fine. I thought the black ground coming from the tank sending unit was the ground for the gauge. I tried to ground it with a couple of alligator clips to another part of the vehicle, but nothing changed? Any thoughts. Almost everything was taken out of the truck down to the frame so alot has changed. The one thing I didn't do was disasemble the dash, only took the face plate off and the top pad. Any thoughts would be appreciated.
    /forums/images/graemlins/bow.gif
  2. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    Details??? Where is it pointing? Factory or aftermarket gauge?
    Shoot me a PM and I can help. I'd say post them but I am working the midnight shift and my brain is not functioning right (compared to when I work days), so I can't garntee (sp) I'd be reading the Posts anytime soon.
  3. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    If you put a new motor in it, sometimes a wire gets pinched that runs from the sending unit.
    That's never happened to me though /forums/images/graemlins/whistling.gif
    I would use a meter and check if you are getting power to the guage from the sending unit.
  4. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    ok, try this. for some reason, could yur gas guage be loose (not making contact enuff ? take off clear cover and give a guage a push to reseat it. might be worth a try. good luck. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
