Gas Gauge on "E" Gauge or Sender?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ford_assassin, Dec 16, 2003.
  1. ford_assassin
    ford_assassin 1/2 ton status
    Nov 8, 2003
    101
    Bakersfield, Ca.
    Gas Gauge on \"E\" Gauge or Sender?
    Hey guys, my gas gauge has been broken since I bought the Blazer 4 months ago.
    It always rests on "E". When I first bought it I disconnected the boot connection under the drive door on the frame. With the key in the "ON" position the needle pegged out at "3 o'clock" like it should. When I reconnected it the gauge seemed to work for one tank of gas and then the next fill up it stayed on "E" again.
    Anyone have any ideas what the deal it? It has only worked on other time since then, and stopped again after the motor was shut off.
    I am really hoping its not the sender, the local dealer wants damn near $300 for a new one. Not sure if its because its a Blazer or because I have the optional 31 gallon tank. Either way that's a big chuck of change.
    Any help is thanked in advance and welcomed.
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Re: Gas Gauge on \"E\" Gauge or Sender?
    check the ground on the tank
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    With a mostly full tank, check the resistance between the wire from the sender and ground. If it's close to 90 Ohms, then the gauge is the likely culprit. If it's 0, then there's a short to ground somewhere. Find that and you'll be golden. /forums/images/graemlins/cool.gif
    On our rigs 90 Ohms = Full and 0 Ohms = Empty. The reading from the sender is linear, so 45 ohms would be 1/2 tank. /forums/images/graemlins/thumb.gif
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i vote for float with hole in it, or flat fell off arm, or just plain bad unit,
    if it was wire from sender to guage that came off or broke then the guage would peg to F
